The system cannot process configuration modifying commands during the configuration save.
Retry the command once the configuration save procedure is complete. If the issue persists, contact technical support and provide the outputs of 'show switch', 'show log'.
Error
The command \"%command%\" was rejected because the system is saving the configuration.
Name | Type |
command | String |
